Sway Bar Shifted
Gedge
I have 2019 F3 ltd. The sway bar has shifted over about an inch or more. The plastic links have bent as a result.
Looking at the parts breakdown it appears to be a bolt on both ends to hold the bar. Anyone know what might be happening here.
Is it a BajaRon bar? Not knowing any more about it. I would say improper install. If it is my bar, give me a call at 423-552-3720.
Get Ron's sway bar and get a 2 for 1.....problem eliminated and handling greatly improved. Yes, the issue may be covered by warranty, but why not take this opportunity to improve that area? And do you really want to be without your bike while the shop has it awaiting parts?
Ron, I wouldn't think so, he said plastic links. Couldn't those cheep plastic links be the problem?
My bad! Someone told me about this and I just assumed it was one of my bars. I didn't even read the post. Monday's are a killer! Still, no excuse for not paying attention. I have seen many times where the plastic links twist. The ball bearings are too tight and can't move so the plastic gives. I agree with the poster that says to get it looked at as a warranty issue.
Frankly, I've never had a customer complain about one of my bars shifting. For that to happen someone would really have to botch the install. I'm not even sure it could be done.
The bolded bit is a 'slight' possibility, but they do have a marked tendency to flex, bend, and eventually break!! (Go on, ask me how I KNOW this occurs! :rolleyes: )
So I reckon the plastic links bending might possibly be the CAUSE of your sway-bar shifting, rather than a symptom!(Go on, ask me how I KNOW this is a possibility! ;) )
Get a BajaRon replacement bar and his end-links, and enjoy ALL the benefits that come with it! (Go on, ask me how I KNOW these benifits are worth it! :ohyea: )
I just can't believe that the plastic links is the only thing to keep bar in place. But if the sway bar is going to move side to side bending the links, then I will get Baja Ron's sway bar.
You will never regret this decision. Trust me.
The plastic links can be problematic. But they do not have anything to do with keeping the bar itself from shifting left to right. The OEM sway bar uses 'Pinch' areas in the bar which expands the steel making it wider (oblong spread) at the pinch points. These are placed just inboard of each bushing. These pinch points ride up against the inside of the bushings keeping the bar centered. If everything is right, the bar can move only about 1/8" (Or Less) in each direction.
There isn't much pressure on the sway bar to shift, so it doesn't take much resistance to keep it centered. I'm wondering if maybe your bar is missing 1 or both of these pinches. Production items can get missed steps. I find it unlikely though as this should have been caught during the assembly stage.
A bar that shifts much at all will destroy the end links. The plastic links took a beating, but they are not the problem, in this case.
Another possibility could be that they used a set of RT bushings on your F3. The RT bar (and bushings) are larger. A too large bushing would allow the pinch points to travel through the bushing. But you would probably get some clunking, thumping or some similar sound in turns if the bushings were loose. Just speculating here. I would love to know the reason for this. Very interesting issue.
This may not help long term, but I found that the bolt running through the white plastic blocks at the ends of the sway bar seemed very loose. I tightened them down and bar has not moved yet. Still going to replace with Bajaron sway bar.
Start planning on how you will raise the front end up enough to drop the bar. Easy remove & replace after that.
That may well be your issue. I hope it is. Easy fix. Begs the question, though, as to why they were loose in the first place. If your OEM plastic links are damaged at all, I highly recommend replacing them right away. You do not want a link to break while running hard into a curve. It can really upset your world if that happens.
Wow, thanks Ron hadn't thought of that at all. OEM links are the weakest point in the suspension.
The plastic links are a weak link in the system. However, if they are in good condition, they hold up fairly well. But if they are damaged at all, I would be concerned. They are most likely to fail under the heaviest load. Which is when you need them the most in a hard corner.
Met a gentleman at a rally a few years ago that showed me pictures of his spyder after one of the OEM links broke. The broken link sent him to the hospital and BRP sent him a new spyder.
