[h=2]
Sway bar removal[/h]
Sorry, got this entangled in another post. Here it is again.
OK, old post-new post, I am putting this post out for advice. Been talking to Bob Denman re a klunking sound coming from the front end of my 2013 STS SE5. And yes, I have checked every nut and bolt I can see and reach while trying to determine the source of the klunk. This sound occurs when the bike rocks from side to side and it sounds like it is just in front of the engine, and about mid way toward the center. History: I purchased my Spyder right out of the crate. It started the klunking from the beginning. I asked my dealer about it and asked for an inspection of the front end. He said the sound comes from the sway bar connectors (heim fittings) and that there is no way to alleviate the problem because the fittings do not have grease fittings, ergo it will klunk till it is well broken in. Another try with him sometime later and he just flat out said I was worried about nothing and that there is nothing to be done. I checked with another dealer who is relatively close and he told me that the sway bar poses no problem and that is is a non-essential part. In fact he continued that many riders take the sway bar off so they can better soar around the curves. Bob suggested this problem about removal of the sway bar should be discussed over the forum. Anyone do this? Sway bar non-essential? Same klunking by others, and if so, result in rectifying? p.s. - If this is a repeat of a similar post, just count it to my old age please. I appreciate this forum and all the advice, comedy and chatter that comes across. Sorry also, I do tend to ramble.
