Couple of things to add that may help you...
1.
This Thread is one of the best I have seen regarding what the Sway Bar does. Also look at the videos in posts #7 and #8.
2. You don't see this mentioned often, and it may not apply to you, but the larger you are, the more difference the beefier swaybar will make. I can personally attest to that. In short, the purpose of the sway bar is to counter the
tendency for the inside front tire to want to leave the road in a turn due to centrifugal force. That, in turn, counters the forces you feel while riding the bike through a turn. The higher the center of gravity, the more you will feel the effects of centrifugal force, pulling you to the outside of the turn (a few inches of difference in COG can be significant). Therefore the larger the rider, the more the sway bar helps.
Interesting side note.... One of the reasons (not the only reason) the new F3 feels so much smoother in the turns (as reported by the dealers who rode it in Connecticut) is because due to the new frame and rider position, The overall COG of the machine and rider is much lower on the bike.
