Sway bar install
Nyparrothead
Hi all,
i ask ask this the other day and got some conflicting answers.. The spyderpops kit comes with two bolts. The direction DO NOT mention them whatsoever. Some have said they replace the OEM top heim bolt, some say the bottom.. Which is it?
mark
Replaces bottom bolts and threads face outward twards the tires per the directions. The top bolts get reused ......:thumbup:
Bottom Heim Link to Sway Bar. A longer bolt is supplied in this kit because the bar is thicker and therefore requires the longer bolt.
This is covered in step #13 of the instruction sheet.
13. Using the LONGER 13mm Bolts supplied (Threads to the OUTSIDE), reattach the Lower Heim Joint Link to one Sway Bar Arm and Tighten (#3) Diagram #2. VERY IMPORTANT! The Sway Bar Arm mounts to the INSIDE of the Heim Joint Link. Repeat this process for the other side.
There is no number 13 on my instructions..... Mine end at 12, if there are updated instructions, where can I find them?
mark
mark
Sorry, I assumed you had an RT bar kit because this is the one that comes with the longer, lower Heim Joint Link Bolt. I answered this in a PM. Sorry for the confusion. It always helps to mention which Spyder model and year you are working on.
