Rednaxs60
Suspension is one of the most important aspects of a vehicle operation, regardless of what the vehicle is. The main purpose of suspension is to keep the tires firmly planted on the road while at the same time providing a good ride and ride performance. To all but a few, this is something that we accept from an OEM, and for the majority it is an aspect of vehicle operation that, if possible, can be made better with aftermarket additions the better.
I posted on another thread, "Bit of a Shock", my understanding of how a shock works: https://www.spyderlovers.com/forums/showthread.php?141435-Bit-of-a-shock-!!
Good banter on whether I am right/wrong, but we all have our understanding of this issue, much like tires, oil and such.
One issue that was mentioned was the stored energy in a compressed spring. Agree with this premise; however, to utilize this stored energy you must allow the spring to release back to the original length. Not doing this you now have a new delta with the same spring rate, and less travel. This is why spring preload is for ride height and sag. Once you have the ride height and sag set, should not have to adjust again unless you increase or decrease the riding weight such as having a passenger, and/or adding luggage. Excessive preload does limit suspension travel, and as mentioned, does impact on ride quality - more harsh. This is why preload should be kept to a minimum when adjusting for height and sag.
Had to get an understanding of the air system on the Spyder. It is very similar to a 1500 Goldwing that has a non-air shock for normal operation such as ride quality and performance. It has an air shock to adjust ride height when a passenger and/or luggage is put on the bike. The Spyder has a rear shock for normal operation, and an air bladder to adjust the ride height to compensate for the added weight.
In this case without using the air bladder, the premise that there is stored energy in the shock spring from the compression of the shock spring is correct. What will happen as you ride the stored energy will try to return the shock spring to its original length possibly making for a rough ride. Good possibility of the bike bottoming out because of this. To compensate for this, an air bladder is used to adjust the ride height to remove the compression on the shock spring so that the shock spring is at or as close as possible to the ride height before any additional weight has been added. This is supposed to give the same ride quality and performance, or very close.
Add to this a system that monitors and adjusts the ride height continuously. This is not a new concept for a motorcycle. I have this system on my '85 Honda Goldwing Limited Edition.
It was mentioned that damping, compression or rebound, can be a nightmare if not correct, BTDT. The benefit is that you can adjust the rebound and if you have it, the compression function, to suit the way you ride and what you expect from the suspension. How fast or slow the shock returns to the set ride height influences the ride quality and performance.
The issue with suspension, and the want to upgrade it to suit your requirements is that it is not inexpensive. There are many aftermarket products that you can purchase at a reasonable price. As long as these products meet your requirements, money well spent.
Didn't want to hijack the other thread so I started this one. Thanks for reading. Cheers
