Suspension Upgrade
oldrider60
I have a 2014RT, We just got back for AZ picking up a 2009GS for a 1st time rider. The owner had progressive shocks installed on the front end. The ride was just rock solid and smooth. Made want to replace the front factory stocks on my RT. I have BjaRons sway bar however I still find the front end kind of mushy. What do most of you replace your factory shocks with and why?. I do not ride 2 up so I am not sure the replacement of the rear shock would be all that necessary.
Steps....
:agree: that would be a good step before you go into the expense for the shocks. Most you will see here are the Elkas but the RaceTech and fox are good and there are other we are seeing like the Wibur and some european ones as well. Don't know if progressive is making them Last I checked for the 2012 they were only making up to the 11's and not the same.
