Bob L
Similar to others that I have read about on the forum, my 2022 RT Limited is getting "Suspension Faults." While back to look at it at the dealership they did find an air leak in the system and corrected that. But, I am still getting the fault, and there is no rhyme nor reason when or why it happens. Yes, my leveler is attached.
Doing some investigatory work myself, I am able to replicate the fault.
I drop some air from the system, so I know that once running and in gear it will call for air.
Sitting on the bike, in gear with the brake off, I hear the compressor come on. It runs for EXACTLY 2 seconds and shuts off. Then there is a 10 second pause and the compressor comes on and runs for 2 seconds again. It does this 2 second/10 second evolution for 5 to 6 minutes, then throws the Suspension Fault notification and the compressor will not run any longer.
On my 2014 RT, the compressor would come on and run constant until it completed its task -- so I am assuming that is what should happen with the 2022. (Correct?)
My educated guess is that the switch/relay that is calling for air is not working properly???
Opinions?
Yes, I will be headed back to the dealer to tell them my findings.
Bob
Opinions?
Bob
