DragonSpyder
When I first got my Spyder almost 2 years (16K miles) ago it had an irratic idle and surged at any RPM. Trying to get any of the local dealers to help was almost impossible. So, I decided to go with the Evolution O2 modifier, race intake and fule pressure regulator. All I can say is the performance was significantly better, especially on the low-end. However, it still surged a bit (not nearly as bad as it was) and the idle was still not as steady as I felt it should be.
So, I decided to purchase a juicebox. I turned back the pressure regulator and reinstalled the O2 sensor. After installation and adjusting the settings I noticed that the throttle was much more responsive and performance was similar to before. The idle was better but the surging was still present and it stalled a couple times out of the blue. It also would stall on decel between 90-100MPH every 2nd or 3rd time for only a second (strong gas smell)
I called Two Bros and sent them the juicebox and they replaced with a new one free of charge. I installed with the same result. So, I decided to replaced the O2 sensor with the O2 modifier. No more stalling down low but the high speed stall is still present. I often ride in this speed range and always seem to be letting off in this range. Scary after passing a tractor trailer! I have tried all the juicebox settings with no success.
I removed the juicebox and looking for suggestions on how to proceed. It runs pretty good without the juicebox but the throttle is not as responsive and still have a bit of surging and irratic idle. Thanks!
