Summer Jacket Thoughts and Other Gear
pludn
Howdy Folks,
I'm looking to acquire a summer jacket for riding the F3-S. I currently have this in grey and find if it's above 80 I become the swamp thing. I am curious what mesh jackets folks recommend and if maybe a kevlar shirt is enough. The current jacket is great for cooler days, and ice cold days with the liner in. I don't really care for the back pad though, it's heavy and bulky and causing back heat like crazy. I live in Va so I'll be battling 80-110 degree weather with this jacket. I also prefer temps on the cooler side so I'll use this a lot of the year I reckon.
So my questions:
  • Do you prefer the chopped or touring cut of the jacket for a spyder?
  • What about jackets with the smaller back protectors like some of the TourMaster?
  • Kevlar button up good enough?
  • Any reason to buy a Klim vs say a Joe Rocket?
  • Is mesh the best for max coolness?
I've read a lot of the threads from the old search function and didn't really find all my answers. I did see a lot of people like first gear though.
The blue ridge shield I have isn't great at letting air into my current jackets vents, but it's amazing at creating turbulence! I plan to replace this with a Route 129 or maybe even a F4 windshield. Two different chains of though there, get more air into vents, or get more breathable gear and enjoy the lower airflow.
Any other summer gear or tricks would be awesome as well. Teach me all the things please!
Thanks,
DP
One Word: Mesh... :thumbup:
attachment.php
:agree: Like Bob said, MESH. If you believe in staying protected even during HOT weather a mesh jacket is probably your best bet. I have a Fieldsheer Mesh jacket that has the waterproof
removable liner. You may want less windshield in hot weather to increase your airflow. I ride a '13 STS that has a manually adjustable windshield, as it gets warmer, down goes the shield to give me more air. It gets pretty hot here but, not having to stop is the only way to stay cooler, intersections and traffic lights are rough as the heat from the road and the engine can be oppressive!!! If it is above 90°F I will try not to ride since you almost have to sit in a bucket of ice to stay cool, and that doesn't seem too practical.
Good luck and ride safe!!!:thumbup::thumbup:
Roger that, these jackets look nice. I agree with the traffic lights as well. The F3 gets soooooo hot at a light.
Mesh is better than wearing even less. I have FirstGear and Gierke to wear when the weather is warm.
I still wear heavy boots, but go down to jeans, fingerless gloves, and Nolan 40 series helmet.
My Thoughts
So my questions:
  • Do you prefer the chopped or touring cut of the jacket for a spyder? ICON ANTHEM in white - full mesh jacket, but a full size (not chopped or touring style) - Mesh in the summer and anything else in the winter.
  • What about jackets with the smaller back protectors like some of the TourMaster? - The pads, in my opinion, heat you up and offer little to no protection if in an accident. You're not likely to low-side on a Can Am so what would the back protector do anyway? A big air bubble would be the best option, but those jackets are hot and expensive.
  • Kevlar button up good enough? - Will this allow you to ride better, because you are comfy with the thought of protection....then go for it. If it heats you up, and causes discomfort, forget about it. Heat can cause you to make mistakes, and get into trouble.
  • Any reason to buy a Klim vs say a Joe Rocket? - Heavens no...for what reason would you buy an adventure style Klim jacket for? Again you're not going to fall off or low-side, so the $1000 expense can be used for comfort in the seat or other mods. I had a Joe Rocket and now an Icon...love those cheaper brands that offer a full mesh option with a few pads for that low-speed accident that may occur.
  • Is mesh the best for max coolness? - If you're going to wear gear, it's the only way to go. You can also choose the Heat-out shirts and soak it in water, then put it on and put the mesh jacket on over that. Also, it's an option to wear heat-out shorts and mesh pants over that as well. When you start drying out, stop and add some water to the garments and keep moving. Blocking the UV and direct sun is better than allowing the skin to burn and dry up...you get dehydrated quicker. There's a reason why middle easterners wear the full garments in the desert.
I am a fan of wearing what you feel is your comfort gear...because that will keep your mind sharp. Once you start over-heating and dehydrating, you get tired and make mistakes. I will say, that I prefer a full helmet of high quality because that is the most important asset you have. Usually they are a bit warmer, but sometimes not because they too have better airflow due to the venting systems (Venturi effect). I have a Shoei RF-1100 which is my absolute favorite. Beyond that, I wear some gear and sometimes not...all about what I feel is comfortable...I've been in an accident on a motorcycle and for me it didn't matter what I had on, I lost the war between a 3500lb vehicle and my 250lb body. Although my body/bones didn't fair well, my head was in tack and no concussion or injury came from the collision. My thought is that a collision on a Can Am will result in a high side accident and broken bones will result, not road rash from a long slide. Just my opinion...hope this helps.
So my questions:
:bowdown: Great post, thanks!
I looked your helmet and it looks great. I have a neotec right now. I often wonder if a one piece helmet is quieter than my neotec.
I prefer a touring style mesh Jacket if you are a large person first gear or cut Full with large sizes. I just purchased there Adventure mesh Jacket from motorcycle gear.com. If you want to talk top-of-the-line go to www.motoport.com website, they will custom make you a ridding Jacket and pants.
Mesh
I have a speed and Strength mesh. It has elbow and shoulder hard protection, back pad and a removable liner. I like it very much.
I have a first gear and scorpion mesh jacket. I rather the first gear. I ride with the back protector in at all times.
i use a full face helmet.i tried a German style helmet for the first time last week and did not like it. I could feel the heat from the street on my face, something I have never felt with my full face.
I use this:
Base
http://www.cyclegear.com/HEAT-OUT-Base-Layer-Long-Sleeve-Crew-Neck-Top
Jacket(white and black):
http://www.cyclegear.com/BILT-Techno-Mesh-Motorcycle-Jacket
Pants:
http://www.cyclegear.com/BILT-IRON-WORKERS-Motorcycle-Cargo-Pants
During the week, I wear a company branded polo shirt over the base. On the weekends, I just wear the base alone or throw a t-shirt over it.
The Bilt mesh jacket is a must. Best thing I ever did. It is armored up so I like the protection
The Bilt pants are amazing. (make sure you try them on at a store. I wear a 34 waist with jeans but the 36 was a better fit) I use them year round and have multiple pairs. Since I wear them at work, I took the CE armor out but I still have the kevlar protection. All of the pockets are great at work to hold stuff. For the past two years, I have had the same 4 pairs of these riding pants and they are not even close to being worn out. I wear them everyday and just throw them in the washing machine when they need it. If I am outside the house, riding or not, I have these on.
Gloves and boots are your preference but I have always gone with Alpinestars. They last way longer then most brands and always do what they say they do. (I have been burned in the past with gloves or boots claiming to be waterproof when they were just water resistant.)
Crazy, but a lot of wind noise comes from under the helmet. If you find a tight fitting neck roll, cheek pads, and a chin curtain, like my Shoei or Schuberth, or icon airmada, you'll find them a lot quieter. Or just invest in a multi pack of ear plugs and use when on the interstate, or if you're going to be cruising around town over 60mph
To the perspective that you don't need as much protection on the Spyder because your risk of a minor-yet-common motorcycle accident like a low-side is non-existent, I'd only remind folks that we can still get thrown off a Spyder in any number of ways that will still leave our bodies slamming into asphalt and road-rashing along the way. The Nanny tries its best to keep three wheels down, but anything built by man can be tricked by man. Likewise, not everyone keeps their seat if/when they get rear-ended on a Spyder.
Bottom line: If you're not in a cage wearing a seatbelt surrounded by airbags and crumple zones, you always assume the risk that you could enjoy an unscheduled dismount from your Spyder. :coffee:
