bikerbillone
Well-known member
Just gotta love this forum, ask a question, get so many good answers.
I have been using them for more years than I can count. Bike, cars, trucks. Get them all the time at "WallyWorld". Cheap, inexpensive safety item! Get the ones in the "RV" section. They have a black outline the can turn so you can fine tune your view. :thumbup: Tom :spyder:
Yeah, I always recommend the ones that turn too, Tom. They cost very little more, but allow you to set the view exactly where you want it once they are mounted :thumbup:
Pete
I have been on the search for mirrors that are less than two inches. Not much of a choice out there.
I found these on Amazon, but not sure of the quality.
--Exco
Gotta say - :agree: . I put mine in the inside lower corner of each mirror, so that if needs must, I can quickly spin them so that I can see exactly where my rear tire is going; but for general use, they are aimed out so that with both I can effectively see the 180 degress behind me - well, except for the bit that either my pillion passenger or I block, but a bit of head movement can usually fix that! .hyea:
I like these alot and found the glass version is way better than the cheap versions.
https://electricalconnection.com/index.php/product/blind-spot-mirror-micro-glass/
Interesting, Peter. I actually put mine on the inside upper corner. That top part of the stock mirror is obscured by my arm/elbow anyway. That lets me use my stock mirror to see below my elbow for traffic directly behind me, leaves the rest of the stock mirror free and the convex mirror gives me wide angle beside me. Horses for courses:thumbup:
Pete
...... I actually put mine on the inside upper corner. ........
I'm glad you said that, because I was going to ask if anyone had ever placed on in the inside upper corner.![]()
I have the swivel, rectangular stick-ons on my car mirrors. Has anyone ever stuck these https://smile.amazon.com/gp/product/B0777JTJGJ/ref=ox_sc_act_title_2?smid=A2N87JPDABE8KA&th=1 on the edge of their windscreen? I'd like something that's more eye level so I don't have to look down and away from the road.
Interestingly, I have had to remove those mirrors on the upper inside since I installed my Daylong seat, Carolanivey. It lifted me 2” and they got in the way. On the plus side, I now only see a tiny piece of my elbow in the stock mirrors, so they are working a treat.
I did use a curved mirror that sits in the middle of the dash in front of you on one of my previous bikes. Yes, your body is in the middle of it, but the curve on each side gave me great peripheral vision. I’ll see if they still make them, as I might give one a go.
They look something like this, although mine was mounted to the dash, not the screen.
https://www.pazomaracing.com/produc...00dMRjNNak1t1Hn0kS_oDx5vB33iByGBoCbMsQAvD_BwE
Pete
I put those tricled mirrors on my 2021 RT and they helped a lot increasing the view and eliminating the blind spots. I was fortunate to catch them on sale (can't remember where). Only problem is when passing another vehicle, you have to make sure you wait a little longer to pull in. Objects in mirrors are REALLY closer than they appear. One idea I may try is to remove one side for a better perspective of distance--might work --hope they peel off easy with a little heat.I use these from TricLED. They are designed specifically for the RT and fit perfectly over the OEM mirrors. They may be a lot more than the stick on 2" round mirrors but I really think they are quality and work well.
https://tricledusa.com/collections/.../products/rt-wide-vu-tricled-exclusive-mirror
Warren
