Suggestion/pics of your manual shift RS floorboards
Squanchkava72
I am getting a cramp in my thigh from shifting my manual shift SM5 and am thinking of going with some type of floorboard setup. It may also just be the position of my leg but it tends to happen to my left leg. I am going to install the Rivco Risers so I will be more upright sitting which may also help with this. My past bikes were a Sportster with forward controls, dual sports, and standard bikes. I don't really care for the pull back on my legs. I do have highway pegs installed, luckily, and when it cramps I can lay it on top of them till it eases up. Of course then I don't want to go back to the normal position. I guess possibly I can keep the highway pegs with the Rivco set up.
I am eyeballing the Rivco floorboards with the heel toe shifter, or using the Phoenix Products shifter kit, and also adding a brake pedal extension. Or getting the SM5 seal boards. I would appreciate some suggestions, opinions, and pics of your set up to show how your shifter works. I am curious if you had to do mods to be able to use your shifter with floorboard set ups. Please share your opinions on either floorboard or different options? I couldn't find any good pics that show the RS SM5 seal boards shifter area. I know the RS is the sport model but that is what I could afford until maybe I can swing an F3 sport to get my legs out front cruiser style.
Thanks
You can look at my thread in the RS Hop Talk section about Issue with Seal floorboards and see what I did. May not work for what you have in mind, but will give an idea.
Mike
Thanks
I'm taller 6'2" and long legs so most every bike I've had caused me to have to bend my ankle to much to shift I have always been more comfortable with my pegs lowered and set back an inch or two ,also adjusting the shift lever helps ,most of the time for me the problem is that the curve in the tank that they have for your knees is for a shorter legs so my knees are forced out of the scooped place in the tank and spreads my legs, lowering the pegs wasn't that hard PM me and I'll send some pic's
I have a 2014 RS and need fwd controls to get comfortable. I can’t seem to find the right parts because I’m told parts aren’t being made anymore. I want handlebar risers too. What are my current options?
