First, I have no financial interest in Dimple Products Incorporated, and second, I have no axe to grind with Gold Plug LLC. That said, the Gold Plug LLC 14 mm magnetic drain plug, MP-02, listed in their plug finder as the one for the Rotax 1330 engine is NOT the same as the BRP OEM M14 x 1.5 engine drain plug or the Dimple engine drain plug. The only thing all three plugs have in common is size, 14 mm. If one attempted to use the Gold Plug MP-02 plug I doubt it is long enough to fully engage the threads in the oil sump. The Gold plug does not accommodate the O-rings required for the OEM and Dimple plugs. Try it at your own risk. Dimple can charge what they do for the pair of plugs because to the best I can determine they have the corner on the market, for now. JMO.
