Jpquinn
when i put the spyder away for winter, i checked and rechecked everything on it including belt tension and it was gaped at 2mm. now remind you it was locked up on second terr of the car trailer. so no one could touch it with out taking the car out and lowering it to touch it. i took it out ran it the 10mi to the house changed new plugs all that and i go to check the belt. now the belt is right up against the rear drive and belt tension is at 200 with the wheel on the ground. any ideas why this would happen? can or does out side temp change what the reading on the belt would be. its a 2009 with just over 8000mi on it. i have a dealership almost next door and asked them about doing a lazer alignment on it, they said with my tires still looking like new with 8000mi on the its a waste of money because they look like new and its unusual for a spyder tires not to wear on the insides first. just wondering others thoughts on this. thanks
