stock seat question
wyliec
The stock seat is tight against the 'Y' panel ahead of it and is rubbing off the paint. Can the seat be moved rearwards?
Seat rubbing
My GS has the same problem. I haven't had time to see if it can be adjusted. I would like to know if someone else has had to deal with this.
:thumbup:
My 08 has about a 1/2 inch of space between the Y panel and the seat, [no rubbing] so i guess it can be moved back a little.
This morning I made an adjsutment to the seat post that goes into the latch. I adjusted it so the seat is raised a little; in other words I lengthened the post (or whatever it is called). It seems to have helped.
You can try pulling the body panel behind the seat, the seat hinge is there, loosen the bolts and see if it will move back and forth, problem is, if it does, then you get to see if the seat lock will move.
john
