Tin Man
I had problems last month with getting my 2012 RT SM5 into gear. I checked the oil level per Lamont's suggestion, and it was half way in the range on the dip stick. I added oil to the top of the range and also checked the clutch fluid level. It was on the low side so i topped that off with Dot 4. Also charged the battery. This seem to work, the bike was shifting again. Now a Month later I went to take it for a ride today and squeezed the clutch Lever and felt nothing there. So I checked the clutch fluid level and it was low again, So i topped in off, but i must be loosing it somewhere. No signs of a leak that i can see. I started the bike squeezed the clutch lever and it felt good again. Shifted threw the gears and it seems right again. I took it for a quick ride to the store and i thought i felt the clutch slip in 2nd gear but it didn't do it after that. On the way back from the store about a mile from the house the shifting seemed to be more difficult so i drove back in 2nd gear and as soon as i pulled in the driveway had nothing left again when i squeezed the clutch Lever. Felt like the clutch fluid was gone again. So i checked the clutch fluid and the level is still full, also checked the oil level and thats full. It might be time to have it towed to the dealer. Only 3000 miles,
