Stays in 1st gear
Anjill
2011 RSS SE5.....Everything works fine except that it doesn't shift into neutral at shut down. This requires me to manually shift into neutral to start it, even if I have the brake pedal depressed. Any advise? Thanks.
I don't think they are meant to shift into neutral on shutdown!?! :shocked: My 2013 RT Ltd (SE5) certainly doesn't do that by itself!! :dontknow: But it does shift into neutral when I try to start & I have my foot on the brake, just like my operators manual says it should!?! :lecturef_smilie:
If yours won't start even if you have your foot on the brake, then that's where your issue is - but I don't they ever were meant to shift into neutral on shutdown tho, so it's probably a good thing that yours doesn't! :thumbup:
It’s not supposed to shift into neutral at shutdown. So let’s review - the SE5 uses oil pressure to move the shifter linkage in order to shift gears. Thus the motor has to be running in order to shift gears. So, if it’s in gear when you shutdown, it stays in gear. Now then, when you want to restart, you place your foot firmly on the brake pedal and go through the normal start process. First the motor starts, and THEN, it shifts to neutral once it gets hydraulic oil pressure. Takes about a second or less after the motor starts. That signal that your foot is on the brake comes from the brake light switch. If your machine is not starting correctly, it’s a different problem than you thought. Do your brake lights come on?
Edit- Oh Hi Peter. Didn’t know you were there.
Thanks .....
Glad it was a simple fix and thanks for letting us know. Hope it was just a one time thing but good your on the road again with things working as they should....:thumbup:
