Soulman327
Not what you want 3 days after buying, but my 2012 RT SE5 ran great till Friday. Then it started stalling at stops....not every time but several times. Frank has been helping me try to figure out the problem but I don't want to be his problem child and burden him with this all the time....
So...I'm asking you all for help/thoughts, as well. Anyway. it had a full tank of gas when I got it and this started at about 1/4 tank. I don't know how old the gas is or how long it had sat before I got it. At stops it would run rough, sputter and die but then fire right up and run fine. Frank suggested filling it up with fresh gas. I did that plus put in some gas treatment (probably more than I should). Still acting up. Will probably take more time.
Today, thought I would experiment. Fired it up, got it good and warm. Ran smooth at 1300-1400 RPM. Then ran the RPM's up to 5000 for a few seconds (multiple times). EVERY time, when I let off the throttle it would run rough between 1000-1200 RPM and after 10-15 seconds would smooth out to 1300-1400 again.
Any help would be greatly appreciated.
Thanks,
John
Thanks,
John
