sKiZo
Picked up an ST2 brake light modulator recently. For those not familiar with the item, it's a GPS adapter that when hooked up to the brake circuit, will cause the lights to flash then go steady on any deceleration. Same concept as the BackOff! and it's clones, but you don't have to touch the brake pedal to activate it. Once you hit the brake pedal, it immediately goes steady. Nice concept - especially on the Ryker. How much of your braking is just backing off the throttle? Kind of a safety issue IMHO with a CVT transmission that does a LOT of engine braking.
Anyway - I also picked up the TrikLED front fender kit. Way kool for upping your visibility. I like them as running lights, but am hoping to hook the ST2 up to those so they flash along with the OEM brake lights.
Short version - no luck finding a brake circuit connection under the hood. Any ideas? I can always tap the line at the master cylinder, but that's a whole lot more teardown ...
Hep me! Please!
PS - the ST2 can be set up to either do the flashing, or just go steady. I'm thinking that the flashing would be way annoying on the fender lights, but it's a pretty easy fix either way.
Hep me! Please!
