ST Mirrors
quickster47
Anyone have any instructions or videos on removing the ST mirrors? I have most of the tupperware on our ST-S off but am stuck on the mirrors and the top piece of tupperware.
Any help would be greatly appreciated.
Carl
Somewhere between steps 4b and 7a you have to sacrifice a live chicken while standing on your head and reciting the lyrics to yellow submarine in iambic pentameter. :(
This is why techs have to go to school for these. So they can figure out how to remove a mirror. :bowdown:
Mirror removal update
Had this info for a week or so but forgot to post it.
When you get ready to remove the ST-S mirrors there is a discrepancy in the manual. The mirrors remove very similar to the RT mirrors once you get all the trim work out of the way.
You can see in my two pictures how the mirrors attach to the main body with the same ball type fasteners.
Carl
The mirrors remove very similar to the RT mirrors..
Thank you for the PICS. I tried using the RT method but to no avail. They have to be bumped towards the rear, how hard a bump? Mine would not budge.
And I thought removing the mirros on the RT was tough !!
John
tupperware
Carl
How did you get the panel off that houses the Radiator fan
John
Hey John,
If I remember correctly it was a more significant 'bump' than what the RT required. In fact it might have been a danged good 'whack'.
I thought at first I had busted something but then realized it was just the mirror housing coming free.
I need to do this again soon so I will try and make myself take better notes.
Carl
I took the left mirror off yesterday. What a pain in the butt. It really isn't that bad except the service manual instructions are just plain wrong.
The first step of removing the 2 allen head screws in the deflector. Remove deflector.
Remove the bottom plastic cover.
Remove the torx screw holding the top plastic cover and remove the cover.
Next service manual instructions is to disconnect the signal light wire. That is wrong that is 2 steps too early and can't be done yet.
The service manual says to push the mirror rearward well that's wrong. You need to lift the outside of the mirror to release the bottom 2 pins from the spring loaded snaps.
When the bottom 2 pins are free lift the whole mirror assembly up to release the top pin.
After mirror assembly is loose disconnect the signal light wire.
Remove the base mounting plate by removing the 4 allen head screws.
Yup the manual is way wrong.
After you remove the deflector, the bottom and top covers... give the mirror a sharp rap straight up. Hit it from the bottom about 2-3 inches out to get some leverage. It will 'bust' loose the two bottom pins from the wire spring type sockets. It will indeed sound like its broken. Then nudge it up a bit more to release the top pin.
When you replace it, slide the top down into the 'V' shaped slot then a firm press in on the bottom will snap the two bottom pins into the spring sockets.
I put anti-seize on the two spring sockets (a tip from Spyderpops - Harvey) which helps them slide in and seems to make removal a bit easier. Did this on the RT mirrors and it made their removal much smoother.
John
