Squeaking Reverse
NOISE IN REVERSE
It's ..... NORMAL - since the very first Spyder , when the brake discs are going backwards they squeak, some more some less, depending on type of PAD ( oem or BajaRon's ), there are special products you can use to lessen the sound or possibly eliminate it ....... but is it worth the effort :dontknow: or money :gaah:to try ....... I notice mine when I back it out of my garage by hand, not a big deal ......... Mike :thumbup:
those mice need loose
I will guess it is the brakes mine do that too but yesterday the left front brake had just a little bit of a rub sound so I think mine is from cooler weather I was riding in ,,, but the bake brake is just the nature of b-r-p pads if I remember reading here
It's a normal sound for these bikes. nojoke
If it's not the brakes causing it: it might be the belt rotating slowly through the cogged pulleys...
