Roy's Bassets
OK, air-dam, belt guard, heat shield, and air system are all installed. I think these are by far the best mods I've but on my:spyder2:. Thank you, spyderpops, thank you.
hyea::2thumbs:
I just finish the installation of the #2 SPYDERPOPS package. It took about 2 hours, not very difficult if your at all handy, simple and straight forward installation. Now if Harvey would make a nice and simple air deflector, instead of that crap BRP sells with the Ultra touring windshield, then I think everything would be right in the world!!:thumbup:
I got package #2 and thought I would start with the belt guard; the easiest I thought. I'm looking at the picture for the RS/GS and can't figure what 3 screws he first mentions; the picture is dark. Are they on the outer belt guard? If they are I see two and a third up front. Is that it?
The 3 screws I'm referring to are the ones on the fender bracket. You will have to remove the one up front also.
Thanks,
Harvey
I used a 10mm socket,3''extension and a ratchet on the back inside nut,other wise it your going to have a hell of a fight.Harvey,
Before I bag this project. Let me try one more time. In the picture, are the two screw at the bottom, which go from the outer belt guard into the fender bracket, two of the screws that are removed? I tried removing one; but, I am having a hard time getting to the nut.
I just went down and looked at it again. You must be a contortionist to get your hand back there or did you remove (what I call) the top, outside belt guard? It looks like I might be able to reach the nut, if I remove the guard.
Thanks
Just put a 10mm wrench on the back nut and hold it. Then use a torx to unscrew it.
Using the 1/4" deep well 10mm socket is the trick.To reach the nuts I use a 1/4" breakover and a deep 10mm socket. It's then easy to feel inside and stays on the nut better.
You make it sound so simple.... :roflblack:
