WilcoJunoHotel
Do you have a pic of the strip, installed?
Here are a few pics. If you look at the first pic, you can see where I had to stick it sideways in the channel at the top compared to it fitting flat in the channel at the bottom.
Probably hard to tell from the photos but you can see how the led parts are angled differently at the top compared to the bottom (both sides). The right side was worse and I am guessing it is because the channel width was even narrower. I am sure that BRP didn't design those channels to any sort of tolerance.
It is not sticking at all anywhere in the curved section - hopefully there is enough adhesion at the top and bottom that will hold in place but I have my doubts.
It if had fit flat in top like it did at the bottom, the curved section would likely have stuck better too.
A little less wide led strip and it would have fit perfectly from top to bottom.
