SpyderPops Radiator Block
Chazzman
When adding the radiator block it says to remove the lower floor pan underneath and behind the radiator. Can someone give me direction on removing the pan? I assume you leave it off is that correct?
Installing the converter shields looks pretty straight forward...Any comments for ease of installation?
remove panel
Just need to remove the lower panel under the radiator. Been a while since I did this but, I thinking there are two bolts
that screw into the frame on one side. And on the other side might be held on by something else, cant remember but
shouldn't be to hard to figure that out once you get started. I'm sure you'll get it without any problem once you set your mind
to it. Good luck! And yes leave it off, that will allow the hot air to pass out the bottom.
There is 2 bolts on the frame and one at the other side. There is a parts manual that you guys can use on the internet for free. The diagrams can be used to see where the parts is and for strip and installation. www.epc.brp.com
