Spyderpops Led turn signal question.
JP58
I have an 2018 F3L. I installed the Led turn strip that gos under the side vents where the service covers are. I have trouble seeing my turn indicators cause I have the short reach handlebar. Well I bought these on the recommendation I could see them flashing. Well I dont unless I'm looking down at them. I see the plug and play harness has 2 connections for another strip. Is there a shorter strip than has a harness long enough to reach my center dash. I want to wrap them around the groove in the cluster cover. Right in front of me. I need it to be 8" or less. I would not think you could cut off to the length you need or can you.
You'll have to ask Spyderpops about cutting the light strip. All of my Spyderpop's light strips are failing. They go out 3 LEDs at a time. Maybe you can cut off 3 and the rest will still work? I put my LED strips on the rearview mirror housing.
