spyderfest Directions
RECOMMEND YOU CHECK MODOT'S WEBSITE
You may want to go online and check MoDots Construction/Traffic Link for St. Louis and the surrounding area. Depending on what day and time you travel thru the area there is alot of construction on some of the Highways in and around St. Louis. May save you some large headaches.
If you decide to come by way of Hwy 270, you need to know that the 270 and 44 intersection has major construction right now. Might want to get off at Big Bend to Hwy 141 S and catch Hwy 44 from there.
Good luck. See you at Spyderfest!!!!!!!!!
You should be good with 255. This is construction time all over. Check the map before you go. :doorag:
http://www.modot.org/tim/
:agree:with G-Man.......come around on I255 to I270 to I44 then on to Cuba. You should not have to many difficulties no matter what time of day (except morning rush hour around the I270, I44 interchange.) Have a safe trip.:2thumbs:
