SPYDER WEB APP - IPHONE, IPAD, PC, MAC, ANDROID, BLACKBERRY
lyonsden
I have the Fault Code section completed so it can be used by all
of the above devices. This is a web app that is designed for a
phone or tablet. It works on a pc or mac but everything will seem
a little large. I still have to add the "How to Check" section.
If you have any questions or suggestions let me know. Be sure and
click the button to add the app to your home screen when you reach
the page the first time. Then you just click the icon and you're
there. A special thanks goes to Rattigan Roger for the Fault code
list.:yes:
www.SpyderHelp.com Don't forget to save to your homepage. (on a pc if you're running IE10 run in compatibility mode)
I must be a dummy, works on my computer but not my ipad, shows up and looks up codes but thats it, wont tell me what the code means
HELP
HELP
Select the code you want, hit search, then you will have to scroll down to see the description. Only thing I can think of is you're not scrolling down:dontknow: When I get home I can look on my ipad if you don't get it figured out.
It won't work on my iPad if I use safari or Chrome. It works with Puffin. Strange.
I just tried it on an Ipad 2 here at work and it works fine. That is using Safari?? What Ipad do you have?
HELP
Try this, on your ipad go into the General Settings, click on safari, make sure that javascript is enabled. When I turn javascript off it doesn't work for me either. So it must be enabled for it to work.
