Spyder ST Error Codes Interpretation?
What Year is your ST evocheck??
Given that there MAY be some differences peculiar to different years, it looks like the following for those codes:
C0063 = VCM Module - Yaw Rate Sensor Defect or Failure. Wrong assembly or mounting position of sensor. Measure voltage between harness connector YRS-4 & ground with ign ON (Expected value =12V DC) Measure voltage between harness connector YRS-1 & ground with ign ON (Expected value =OV DC)
C006C = ECM Module - Communication intermittent/erratic &/or Check Sum Error. May be triggered by U0122 (ECM) or U220B (ECM) or any VCM DCT Blown fuse. External troubleshooting is not possible. Check for communication fault.
C1083 = VCM Module - Pillion rider switch shorted to V-bat. Defective Pillion switch or Switch shorted to battery. Dosconnect VCM & PRS connectors. Measure voltage between harness connector prs-b & ground (expected value = 0V DC) Replace Pillion rider switch.
Hope this helps some. Good Luck! :cheers:
:agree: & any :spyder2: when multiple codes all to unrelated functions pop up, good idea to double check battery connections. Go ahead & disconnect completely let set a min or so while cleaning terminals & connections (careful to not short anything out)
Can be bypass for test this sensor? have three wire blue red green
