Spyder RT Shifter Adjustment
flyinhgh
I moved my Rivco floorboards up on my 2011 Spyder RT-S and want to raise the manual shifter up some. I can't find any documentation on how to do this. Is there anyone who has done it or has the reference?
Thanks
Depends...
Will depend how much and what shifter pedal you have. My RS has adjustments on the shifter toe arm with some adjustment there but if you do not have that or need more you will have to go to the shifter arm attached to the shift shaft and remove it and move it a couple of splines. :thumbup: may take a try or two to find the best position....
