Marker
I'm not sure if this is normal or not.
I've noticed on my '10 Spyder RT-S that the left-hand control cluster ... the cluster that includes the mode button, turn signal control, windscreen adjustment, mode-directional up/down/left/right ... seems loose. It's not 'flopping around' or anything and all the external screws are in place, while there was some room to tighten a little. The 'looseness' means that the assembly is able to move up/down around its axis on the handle bar by aobut 1/4 to 3/8th inch. Its position affects how solidly my thumb hits the turn signal. I try to nudge the cluster position to it's highest point which works the best. But is this normal, and if it isn't how does one tighten its position on the the steering/handle bar?
*Help*?
Thanks
Hi
I had the exact same issue as you are experiencing and the cluster would not tighten when my dealer tried to tighten it . My dealer had to replace the cluster under warranty and now the new cluster is tight and does not move. You need to contact your dealer and have your :ani29:'s cluster replaced
