Spyder RT front tire size change
AZCowboy
Does anyone know what size tire for the front you can use in place of the 165/65/r14? I am looking for a good tire for wet, dry and sandy roads with a H rating? To get them without buying the stock tires which one came apart inside with less then 5K on it. I can't find any in the stock size but don't want to have to mod my fenders either? :f_spider: RJ
I JUST FOUND THIS TIRE SIZE ???
I didn't even know they made this size 185/55-14.......I don't know what the circumference or width is but I am going to find out.....Nice looking tread pattern and " V " speed Rating........Mike..:thumbup:.......It's a Yokohama S.Drive $ 77.86 @ onlinetires.com--------Just put in the tire size and it will go direct to this tire + 4 others.........More info the circumference = 945 revs per mile vs. OEM @ 926......and the width will fit under the fender.....The big difference is the footprint of this tire is HUGH 6.7 INCHES and only a hair wider than the 185/60-14.....The OEM tire only has a 5 inch footprint. :2excited:
Different sized front tires
Do you folks with the bigger footprint tires notice any significant handling differences from the OEMs? With a stiffer set of tires, I'd imagine something would show up. Then again, what do I know?
Tuck
YOU MAY LOTS
Tuck
Tuck, I haven't made the purchase yet on the Yokohama's ( 185/55-14), but the tire specs lead me to believe that that is the largest footprint of any tire that will fit under the OEM fender...Footprint equals increased lateral traction ( for front tires) and more-so on the BRAKING ability. The people who race bicycles ala TOUR DE FRANCE can very very easily lock up their wheels because they have almost NO RUBBER CONTACT on the road.....Granted a larger tire footprint can more easily lead to HYDRO-PLANING but this can be mostly controled by the operator by just slowing down.......at any rate I'm going for the bigger footprint....Mike...:thumbup:
Thanks, let me know how they work out, please.23
I wrote a note yesterday about my Kumho rear
It does great with no hydro planing, but it has done some dances on an aggressive start on wet surfaces
Did a big time one on Wed on an on ramp to I75.
That was the 4th time, others on county and private roads. The originals never did that - two tires in 28000 miles
Tuck
I am not a throttle jockey so it was a surprise. I was wondering about hydro planing due to the wider,stiffer tire with less weight on it.
Tuck
Thats a concern as I am about to install a new Kumho on the rear and have never had traction problems with the oem rear....
Anyone else have a similar experience losing rear traction, either with the Kumho or other car tires on the rear ?
Is the Toyo likely to be much better?
Run flats on a 2012 RS Spyder
The Altimax tires look fantastic I wonder if they would fit my 2012 Spyder RS with a good fit and not rub the fenders, but has anyone found and put on run flats for the front and rear tires? Any recommendations close to stock sizes?
