crazy_larry
I bought this great used 2010 RS SE5 earlier this year. The Spyder has the Givi R-35 saddlebags and mounts. From what I can see I will need to remove the bag mount on the left side to replace the battery. Correct? If so, what kind of tool is necessary to remove those tri-shaped bolts? I've never seen bolt heads quite like that before. If the tool is required, does anyone know where to get one?
