spyderwing
Put on a General Altimax and new rear wheel bearings- all is fine but next day the 2012 Rss-Se5 started to run really lousy. Cold start and die when put in gear-run very weak. As it warmed up it ran better but still sputtered and surged. Thought maybe water in gas. New gas and Heet did very little to help. Then read about the cracked hose on the MAPS- manifold air pressure sensor. It was very cracked and deteriorated. Taped with electrical and gorilla tape. Did the trick- runs fine. Did that on Sunday to save time. Changed to a new hose today. There are 2 hoses- calling them front and rear. Close together. The front was bad-1/64th inch inner diameter. The rear is Ok so left it alone. The rear is larger- 3/8ths or 5/16ths in. inner diameter and looks longer than the front. Amazing difference the little hose can cause. Easy change & thanks to all who posted about the problem. John
