Spyder question
mcguire1511
It seemed to me , while riding my:spyder2: today that at a steady speed, 40,50, or 60, that while holding those speeds in the right gears, the spyder seems to hesitate or pulsate, like it's gaspping for air or something. It's not the parking break, nor the wheel pads rubbing..Help...........Thanks
You supposed to be in the 2nd gear, right?
a man cam in to the dealers shop with simler problem found he stored his :spyder:out doors in shead
found a nest in air box ..mice lol
Ken's 02 modifier may smooth things out, mine used to have a surge at those speeds while cruising along, due to lean fuel mixture, smooth as silk now.
I've noticed the same thing on my :spyder2: when the rpm's are between 3800-4200. It doesn't seem to matter what gear it's in as long as I'm in that rpm range. I talked with wbbrn1952 tonight and he is going to monitor his :spyder2: and see if he's getting the same effect. I don't have any surging in a higher rpm range. I talked with a man who has SE5 and had the same problem with cold starts and low speed surging. He installed a juicebox and he has had no problems since. I will be installing a JB very soon.
