Spyder on fire?
  • Thread starter Thread starter reggystan
  • Start date Start date
My clamp/hose to my gas filter has come loose twice now, so much so I had to replace the clamp. I noticed gas had been leaking underneath on start up only. I was told because of the high pressure on start-up this hose/clamp can come loose.
The gas comes out by the gas filter and runs down the hose to the bottom, this is where I noticed my leaks.
Replaced the clamp, so far, no leaks.
I agree with you on your points but I'm sending you a dictionary! :yikes::D
I'm sending you this one:
:D
We were commenting in Chicago that the fires happened all about the same time and then just kind of stopped...... strange.
We still don't know what the issue was-- only some good guesses....
Some of you probably remember when I had a fire on an 08 SM5 last year. Well I would suggest to all... check up under the instrument cluster next time you have the side and top tupper ware covers off. The reason I had the fire was due to the fact there was a white terry cloth left under the the plastic that surrounds the cluster. The cloth fell down on the front cylinder exhaust line and started to burn.
Fortunately I stopped near house that had a water cooler laying in the front yard that had water in it. I poured the water on the fire and put it out. Only damage other than some smoke was to my nervous system.
So inspect anyplace where a cloth could have been left by a service facility. Ken krb1945
