Spyder Magneto
I run heated jacket- 77W, heated gloves- 27W, GPS- 10W?,
in addition to the Spyders normal load ont he system from the computers, ignition etc. My voltmeter tells me I have full charging output at any road speed. It does drop at idles- reads 12.7-13.1, but as soon as I get rolling I see 13.6 to 14.1 at all rpms- 2500-7000.
That is some good information! I was wondering about the my Spyder's charging systems with my GPS and heated grips (Hot Hands). I think I'm in the clear.:thumbup:
Thanks for posting.
Cheers.
Spec for charging is 15-20 amps (out of a capacity of 40) at 4000 rpm. In short, the system puts out about half its rated output halfway to redline. Spec for voltage is 13.0-14.8 volts at 4K. The voltage is really just a check of how well the regulator is working. Too low won't charge the battery, and too much may fry things.
second battery ?
Didn't several members that have added additional electrical items add a second battery?/Ken
Inquiring Minds Want to Know
Has anyone looked into putting the higher output magneto from the new RT model into one of our older RS's :dontknow: That would be of great interest to me. In the winter I have two sets of electric gear to keep warm. :yikes:
We all know the Spyder doesn't like a low battery. :( Weird things happen when the juice is low. nojoke
yes:D
Where would you connect the wires from the volt gauge to get the reading, I was thinking of putting one on my SE5.
In my case I already ran wiring up the the back of the instrument cluster from the battery to install a PC-8 auxiliary fuse panel, so I just wired the voltmeter to the panel ground and fused the + side.
