1330cc Spyder leaked all the oil out TWICE
Just throwing this out as “food for thought” and an event I experienced. I had an oil leak in a VSTAR a number of years ago and I traced it back to a broken graphite like gasket between the exhaust and engine head. I’m not sure how the Spyder is set up and if this is even possible in your situation but in my case the leak was not where I figured a leak would occur.
Poasttown, 2019 F3L
Mike, what’s your issue? The bike lost the oil when he was in Tombstone, he trailered it to the dealer in NM. It had not leaked oil before his trip to AZ. Ease up dude!
He is a she, her name is Gwen a friend of mine. And having worked on motorcycles and other vehicles over the eons, this has me perplexed as well.
On Tuesday February 4, 2020 the shop called to say my bike was repaired and put back together, test driven twice and all was right with the bike. I brought my Spyder back home on Thursday 2/6/20. I will post detailed repair info soon, as I currently do not have all the proper names of the parts, etc. I can say that the oil leak was an overfilling situation, but due to the problem that caused it to live at the repair shop for the last 16 weeks - which was - if we all know with 100% certainty that there is exactly 5 quarts of oil in the bike and did the BRP recommended procedure for checking the oil with the dipstick, then WHY was the oil not registering ON the dipstick? The dipstick was verified to be the correct one for that bike, mounted correctly and in good working order. Turns out that had the bike not ejected the excess oil thru the air filter and then out of the bike entirely, no one would have known that the oil reading 'low' on the dipstick was not an indicator of a need for oil, but a small, oval-shaped gasket that was missing, therefore not letting the engine build up pressure enough to return the oil to the reservoir from the crankcase, but would occasionally get up enough oil to show a need to add oil, when in actuality there wasn't. So once the leaking oil problem was solved, the next step was to go thru and replace all the gaskets, 2 O rings and test the system again. After numerous emails to and from the engineers at BRP Canada and BRP Juarez, Mexico it was decided to double-check 4 potential causes of why the dipstick readings were showing to add oil when the system was full. One by one things were checked and rechecked, items were replaced, oil refilled, but still no luck - until they get to #4 of 4 things to check. #4 turned out to be a missing gasket on the right side, possibly falling out/off when that cover was removed to replace one or both solenoid. And since the mechanic apparently did not see that gasket fall out when the cover was removed, no gasket was replaced when the cover was replaced. So, a missing, small 1.5 inch, oval-shaped gasket was the root cause of all of this mess. My Spyder and its issues have become well known throughout BRP. Thanks to all who offered suggestions and who were just as interested and perplexed as I was. �� Gwen
:clap::clap: Glad you got to the bottom of it!!! Now get out there and ride that thing!!
I've been working on machinery for 40 years. Copiers and printers specifically, but many intricate mechanical systems with precise repair procedures and adjustments. A piece of paper is about .002 thick. Some of my adjustment specs are +/- half that.
In life, the motto is don't sweat the small stuff, in repair, it's often the small stuff that makes you sweat.
Don't overlook that a mechanics job is often to find out what it isn't, so you can find out what it is. That takes time.
Glad for you it's repaired. Quite possibly more glad you know who and what you are vs. some of the confused youngn's I see coming up behind me.
Go for a ride!
Well, the fun will have to wait a few days - I work weekend night shifts and it is too chilly for me to ride at night...soon though, very soon. I did take the bike on a victory lap around the shop's parking lot during the day - that felt WONDERFUL! And I see some lovely road trips in my near future, although I think we will go back to Tombstone/Bisbee later in the fall again...with much better results this time 😉😉😉
Glad to read that the issue was identified and fixed.
We will be heading to Bisbee on the 17th and stay at a B&B for two nights. We have been told by a number of people not to miss seeing Bisbee, so going to do that as my birthday gift.
Take the Silver Mine tour - very cool, kinda spooky 😉
Explore the numerous shops and if you're both able - walk around. Parking can get a but interesting, but it's doable. Enjoy your trip and Happy Birthday to you!
Gwen
OK - So I've talked with the service manager at the shop .......they are using the power of the internet as well... :read:
That is weir why are the dealer not consulting with the Manufacturer directly who made the product that They are trying to solve a problem on. Bring the questions directly to the source. BRP is supposed to have "experts" on every part of their products and potential problems and solutions.
They internet mostly produces anecdotes from people like me that are not 'experts on anything' but have opinions on everything and time to make videos etc.
