Lamonster
SpyderLovers Founder
I did this video explaining the process of aligning the Spyder with the laser alignment tool. I forgot to add that you need to check BUDS after you're done and make sure that the steering angle sensor and torque sensor is set to zero when you're done. Boring stuff for the gals and some guys but the gearheads will like it. :doorag:
Here's the pics in the video.
This should have read 28 1/4" not 28 14"
pps::banghead:
Don't forget to check BUDS when you're done and make sure your steering angle and torque sensor are set to zero :doorag:
