StriperKing
2010 RTS SM5
OK first I am way more mechanical than most so get as detailed as you want.
So we were riding the other day for a couple hours then all of a sudden the bike just shut off twice for about 2-3 seconds but never completely shut down and never acted up again that day. We then went on a ride for 185 miles and not one issue. Then tonight I rode for about 1 1/2 hours then while going down the rode at about 55 MPH just shut off and coasted to a stop. All the lights and guages were still on brite so I put it in neutral and hit the start button and nothing. I then turned the key off for a couple seconds, turned it back on, the comp. cycled and I hit the start button and it fired right up. I went about 100-200 yards and the same thing happened. This happened about 5 times but after the 5th time it didn`t do it again and I rode home for about 1/2 hour ride. It acts just like you hit the kill switch, not a miss, stutter just shuts off. So here is what I have checked:
1. Gas tank half full
2. Battery conections were tight and the battery is only a couple mo. old
3. Checked all the relays under the seat and in the frunk and all were tight but I pulled them all out and re-inserted them. They were all clean also.
4. I tried to wiggle the kill switch while it was running and did not do anything.
5. I wiggled the key while it was running and it did not do anything.
If it were not for the shutting off you could not ask for it to run any better. It is just as crisp and responsive as always and there are no faults, codes, warnings, nothing. Anything I am overlooking? I really felt it would be a loose relay and it still could have been but who knows. My gut feeling is one of the relays is going bad but there again who knows. It would be better if it just quit and stayed that way then it would be easy. Sorry for the book but wanted to give all the details.
