You might want to put foam grips on they help your grip they made a difference for me
Geeezzz . . . and I thought I was the only one who did that . . . :cheers:
........ By the way, what tire presurs are you running now, i have 30 rear and 18 front on the Kends.
Just be a little wary of varying the Kenda tire pressures too far from their recommended pressures. They really are a lightly constructed tire, and while going a little up or down is usually OK, going much beyond about +/- 2psi means you are inviting all sorts of uncomfortable &/or potentially dangerous issues! :yikes:
But it's good to hear that you are enjoying your Spyder already! :thumbup: They are a fantastic machines once you get over the niggles & idiosyncracies that frequently beset new ryders! Now all you hafta do is get out there & start racking up the miles!!hyea:
Oh, and now you're properly up & running, check out the Spyder Muster website - www.spydermuster.com.au - many of the Aussie Spyder Ryder community will be heading West to attend that gathering of Spyders in late March next year - WA in 2020! From up your way it should be a fantistic road trip, but if you don't want to cross the Nullabor on your Spyder, we are exploring a variety of (not massively expensive) ways to get people & their Rydes over there, just keep an eye on the website! :thumbup:
Looking forward to catching you out there one day! :2thumbs:
If your running stock tires your going to want to watch your tread wear close and find the right pressure for you, meaning weights you hall, two up riding, ect and find one the keeps your tread wear even across the tire as you can. To much air you'll wear the centers out not enough sides! That's where IMO lots of people that say you should use this or that, are falling short. Tires, oils, are always a good thing to start a hornets nest going and the most hardest areas to make a disstion because everyone has there own twist to the problem!
Lots of good advice here. One thing to remember if you are coming off of two wheels: With two wheels leaned into a corner, "G" forces are aligned with the vertical axis of the bike, pulling downward on your body. In most cases this is not even noticeable. on a three wheeler, any change in direction (from straight), no matter how slight, will exert lateral "G" forces in the horizontal plane, pulling your body side to side. To an inexperienced three wheel rider, this may feel like twitchiness. By relaxing and easing your grip, you will eliminate some of the minor side to side excursions that cause the twitchy sensations. Also be aware that Spyders have more wind loading surface area than most two wheelers, so they are more sensitive to cross winds. It took me a while to get used to these characteristics, but now I seldom notice or think about them.
Just learn to relax and enjoy the ryde.
BTW, I still switch back and forth between two (Harley Road King) and three wheels, and the adjustment is automatic. I don't even think about it, except when I catch myself reaching for a clutch lever on the RTL.
Just make sure your phone/tablet/computer battery has a full charge!Lol I love your epic tomes Peter, keep em coming!
