i installed fuel mixture tuning thingy(it's simple little device to trick spyder to think it's colder to feed itself more fuel) from magnumtuning and took the splash guard off.
i rydden enough to say magnum tuning thing does work and splash guard removal has not changed much.
i set the tuner to it's highest setting and it pulled much harder on all the gears but really could not put all spyder's added torq on to pavement. i probably need a suspension upgrade now...
i don't think i will ever get rid of first gear blues with a se5. it still is too sluggish off the line. with se5, i do not have the option to start off the line with higher rpm and i believe that's what's hurting my start off the line.
once spyder gets to rpm she likes on first gear, it takes off so hard i do have to hold on HARD rest of the gears. i set the tuner back a little to save on gas(spyder was consuming alot of gas) but, i am gonna have to turn it back up and just exercise more self-control
to go easy on the throttle.
removal of splash guard did not do anything on stop and go traffic as expected, but also did not do much on moderate speed ryding or at freeway speed. they will go back on when i do oil change and do that fan controller thing or just a manual switch.
