Speedometer
Tuner
I was riding today when I noticed that the manual speedometer was reading 10-12 mph higher than the digital one. No other problem occurred. Has anyone else had this. 2017 F3 Limited 5200 miles
There have been reports of 2-8mph differences between dash & gps , but can't say Ive read about the digital & analog being off on same unit:dontknow::hun: Mighty odd hope was a fluke maybe just bump related momentary at best. Please double check & let us know. :thumbup:
A couple of years ago I stopped for gas, shut the engine off with the kill switch, turned off the ignition switch but turned it right back on because I has not set the parking bike. When I restarted and rode off I noticed my analog and digital tachs were reading several hundred rpm different, don't remember which was reading lower than the other. Later on the ride I stopped for a drink, again shut off the engine with the kill switch and turned off the ignition switch, pulled the key and left the bike for 15 minutes or so. When I restarted the Spyder both tachs were back in sync. Has not happened since.
Yes I have had this speedometer issue
A number of times on longer trips and usually after a long time at hwy speeds, I have noticed this too. "sometimes" it clears up right after I stop for gas, and other times it takes longer - like overnight. Don't know why. Almost bet BRP wouldn't address anyway.:banghead:
The analog gages reset themselves everytime you turn the key on. If for some reason the needle is not able to go back to the zero position. It will be off on the high side while running.
