spark plug access
Stand on your head, turn around three times, and hold your mouth just right. Seriously, there is no easy way. From the right side it requires removal of the airbox...and often a couple of extensions and a universal. Supposedly it can be reached from the left side by feel, with a stubby ratchet , but I have not tried that approach.
Remove the Airbox & Resonator and replace with the KewlMetal Intake Kit! All service access is simple after that.:thumbup:
:clap: :yes: :agree: :yes: :clap:
See that RED wire in the middle of the mess? That's BajaRons new wire set leading to the front plug that you seek ;) As cjackg stated, with the airbox removed & replaced with the KewlMetal Air Intake Kit, it makes any engine/interior work so much easier :thumbup:
Could they have just used the same head as on the rear, and turned it around for routing the exhaust and intakes better?:dontknow:
