spare key?
problem
Ok I used the master key and can am brp cut blanks.
But the 2012 rts will only let me program 1 key.
It never gives me the next key option. It just says success and kicks me to the main cluster screen.
Help please.
This same kind of system is used by other manufacturers. Here are the steps from the manual
To add or reprogram a key, carry out the following steps:
1. Insert an already programmed functional key
into the ignition switch.
2. Turn the ignition key to ON.
3. Turn the ignition key to OFF.
4. Press MODE button for 3 seconds.
5. Wait 5 seconds.
6. Remove programmed key.
7. Insert MASTER KEY (P/N 529 036 106).
NOTE: The master key is purposely “not cut” and will not turn in the ignition switch.
1. No notches
2. RED colored
8. Wait until the cluster displays MASTER.
9. Remove the master key.
10. Insert a key to program.
11. Turn ignition switch to ON.
12.Wait until cluster displays NEXT KEY.
13. Turn ignition switch to OFF.
14. Press MODE button for 3 seconds.
15. Remove key.
16. Insert next key to program.
17. Turn ignition switch to ON.
18.Wait until cluster displays NEXT KEY.
NOTE: If there are at least 2 keys programmed and you do not wish to program more keys (4 maximum), leave the last programmed key in the ignition switch. If you wish to program another key, repeat the previous five steps.
19.Wait until cluster displays SUCCESS.
20. Turn ignition switch to OFF.
21. Remove key.
Key programming procedure is complete.
NOTE: When the maximum of 4 keys are programmed, the cluster will display SUCCESS. Start engine and let run for more than 2 minutes. If engine does not stop on its own after 2 minutes,
programming mode is complete.
Same Problem
Were you able to find a fix? We had the same problem with programming our 2013 RT Limited. It will only allow us to program one too.
Help please.
