Spare gas
Bfromla
Well-known member
attachment.php
My bud has one on his VTX1800. Helps get more miles & looks good. Know they can do a spyder too. http://www.tourtanks.com.
Cool..!!
those are nice tanks. Like little beer kegs :roflblack: but a great add on for those out back country roads where gas stations are fewand far between...:thumbup:
Interesting.
Looks good.
Is that just a spare can of gas or is it an auxiliary fuel cell that has plumbing to the injectors?
If you look at the plumbing kit that comes with them, it seems to have plumbing to splice it into the fuel line with a 3 way tap.... not sure that will work too well with most injection systems - they need return lines as well, so it'd need to be a 6 way tap to work in-line with the injector system; but it does seem that the gear they provide could readily be adapted to empty/drain or transfer the contents of the spare tank into the bike gas tank, simply topping it up via the tap once the main tank level was low enough to accept more fuel! :thumbup:
