Spacers
Eraser
Anybody else notice a "spacer" between the hub and the fender mount?(on my 2010 RS) They are approx 9/16" thick and the mounting bolt for the fender passes through them.We could not find them on any bike that the Dealer had except mine.BRP explained that it was something related to using only one hub for both RS and RT. If you remove the "spacers" the inside of the fender will rub against the tire.
I bought the front axle covers and could not install them.The bolts supplied were not long enough and the bolts holding the fender on will not fit in the cover.New,longer bolts have arrived today.If you have a 2010,check it out before you order the axle covers.Sounds kind of wierd but honest,the "spacers" are there.
