Sonic Tension Question.
h0gr1der
All,
Just got my machine (2018 RTL) out of warranty limbo, checked it over before riding home and wouldn't you know it, the belt is too tight and vibrating. Even with the dampener on the belt.
Looking through the paperwork on the 3000 mile service, the tech acknowledged everything I asked them to do. I run the axle torque at 25% less due to lubricant on the threads, don't fold my split pin over, just slightly spread it, etc.
In reporting the belt request, I had asked them to skip the belt unless they couldn't. Paperwork said belt far outside of spec, set to minimum spec as per customer. They then reported the spec as 950 Hz.
For those of you that use sonic testers, is this a typo? Did they mean 950 Newtons? I saw ± 200 Lbs on the Krikit II, and 950 Newtons is 213.5 Lbs. converted.
I suspect 950 Hz would be somewhat high.
Gates Sonic belt testing app......Iphone - Try it out?
It's my understanding the phone app is most accurate when the phone is placed on the floor(no hand shake)while testing.
I'm not sure but I believe the Spyder manual references a Gates sonic meter P.N. 529 036 115.
What I'm looking for is someone who has used the OEM sonic tester to tell me if it reports back in Hz, which necessarily would have some kind of conversion to Newtons or Lbs of force.
I measured about 200 Lbs of force with the wheel on the ground at the dealership before I rode it home, and it vibrated pretty badly. From my past settings, that should be around 170 lbs in the air. Just wondering of someone can supply a correlation between 950 Hz (wondering if this is a typo) and the 200 lbs force with the wheel on the ground.
I'll measure the wheel off the ground force when I go to reset the tension to my normal range (150-160 Lb. on the ground for me).
1,000 hertz in pound-force = 224.8 lbs of force
950 hertz in pound force = 213.5 lbs of force
900 hertz in pound force = 202.02 lbs of force
https://converterin.com/frequency/hertz-to-pound-force.html
That doesn't make any sense, the frequency will depend on the length of the vibrating member. For a given tension, half the length will be twice the frequency.
My belt is approximately 110hz on the ground. I reckon that's possibly on the tight side.
I was attempting to convert the 950 number you said the dealer had written down. Along with your 200 lb guesstimate when you measured it at the dealers.
Wish it would have been worth the effort........obviously it was not. Sorry bout that:)
Hehe, no problem, it wasn't me who asked!
PARTS AT ROOM TEMPERATURE AND REAR OF VEHICLE LIFTED) 1050 N ± 150 N If the tension of drive belt is out of specification. I think its a bit less with the bulletin that was posted awhile back.
And set your meter to
MASS WIDTH SPAN
008.0 g/m 28.0 mm/R 0980 mm
Now for hertz to newton is above my pay grade but if I get a chance soon I could test it with my meter just to see what it comes out too.
Mr. Jeriatric,
Wasn't me that twisted your tail! I was just asking a question because at this particular time I am ignorant. Soon, I will not be. Many folks have a hard time wearing that cape, but I'm not afraid to ask the ignorant question, especially if I don't know.
I appreciate everyone who contributes to my conversations, even those on a tangent. It moves the conversation forward and also fosters camaraderie.
MASS WIDTH SPAN
Mr. tirkermutha,
That's what has me confused. The 950 is close to the lower recommended tension (±50 N), so I was just wondering. Another thing that is hilarious is that in both my 2018 and 2019 RTL service manuals, in the drive section they spec the 1050N ±150N, but in the back under Technical Specifications-Vehicle, page 4 under Drive Belt, it lists 775N ±150N, yet they never, ever seem to acknowledge this lower tension. even to the detriment of their customers.
Mr. tirkermutha,
I know they revised the tension and seems they posted the original and revised in your manual. But you mentioned Hz versus N.
So what is 950 HZ in "N"
And as posted above it sounds a bit High post #6 versus the IBF you posted 174IBF but is acceptable
Given that mine is about 110Hz and I think it's a little tight, could they possibly mean 95Hz?
Ms Spyderlass,
I haven't a clue how the sonic tester works as I've never seen one. I don't have any idea as to whether it reports hertz only, or does the force conversion. Not sure of the belt frequency either, saw a video that Mr. Jeriatric provided for the Gates app that showed frequencies of 35-75 Hz for tensions from 28-53 Lbs, but don't know how that correlates to the long RTL belt.
Mr. Jeriatric,
I'm laughing. I don't think anyone twisted my tail. There's a line under Jeriatric that says - thinks out loud - because I do. Trial by fire is a good teacher.
The Sonic must be feeded with data from the vehicle/belt.
After that you can choose what kind of report you will see on the display - either HZ or N..
I need 1050 N belt tension and this is about 33HZ - i am driving an spyder STS SE5, My2014.
Greatings from germany
Ok, I'm kinda dense, but I finally pick up on not too subtle clues. Ms Spyderlass and Mr. Germanspyderrider have both indicated that the 950 Hz the tech put on my service report is an unreasonable number (110 Hz on whatever Ms Spyderlass is testing, and 33 Hz on an STS), then I must conclude that the 950 number referenced has to be in Newtons, and is a Typo.
I had asked my dealership to put the belt at minimum specs, and the 950 Newtons is way above the 625 Newtons minimum listed in the book. (775N ±150N=625N).
If all this is true, then I have a basis to write their service department a logical complaint, which may make them learn something, which may make the next poor bastard that has to deal with their BS a more satisfied customer. We only get better through learning.
