Belt tension APP for Iphone,Ipad and Ipod touch
  • Thread starter Thread starter Doc - Riverside
  • Start date Start date
lbs =n
If using a Krikit tool how many lbs do you set the belt tension ? Are there new guidelines? Just put on a new Kumo and want to check everything.
I just adjusted my belt after installing my hitch.
I can tell you it was extremely hard, not adjusting the belt, that was easy.
Asking my daughter if I could borrow her I-phone which I pay for.
so I could adjust the belt, and hearing over and over don't hit my phone with that hammer!
Stefan
BTW I jacked up the bike and put a box under it and just laid the phone on it, so it stayed stationary.
before I removed my belt I took a measurement with the krikit and marked it. never using one before when I put the belt back on it wouldn't read anything.
I finally realized that the belt was too tight and was past it's limit.
Also, does it matter if you strike it versus plucking?
I use a small ball peen hammer. I use the ball end and tap the belt with a small amount of force. The key is to try and strike the belt the same as you take the three required readings.
OK now lets really make this simple so all you have to do is get a frequency reading and convert it to Tension in Newtons. If we plug the above belt data into the formula we come up with two number that are constant. So now all one has to do is take the frequency, square it and multiply it by the constant for your belt configuration.
[TABLE="class: outer_border, width: 500, align: center"]
[TR]
[TD]Belt[/TD]
[TD]Constant[/TD]
[/TR]
[TR]
[TD]V-Twin (Span 1028mm)[/TD]
[TD].99422[/TD]
[/TR]
[TR]
[TD]ACE 1330 (Span 980mm)[/TD]
[TD].86052[/TD]
[/TR]
[/TABLE]
If frequency is what is being measured, and we use the conversion factors you have earlier in the thread, then a specific app is not needed, right? A laptop with an audio recording and editing program using an external microphone will provide the needed number, won't it? Same thing with an Android tablet, if it has a decent audio chip in it, right?
Installing a tensioner could take less time than READING all that, much less understanding it! Not that I DON'T understand it, but finding a mike and downloading a program is probably more trouble than installing a tensioner.
Expected Frequency Range one should see based on belt tension for your Model SPYDER. Keep in Mind the APP will not give you a reading below 20hz (it displays <20.0hz)
[TR]
[TD]V-Twin Belt All Models (Years 2008 - 2012)[/TD]
[TD]Min (300n)[/TD]
[TD]Spec (450n)[/TD]
[TD]Max (600N)[/TD]
[/TR]
[TR]
[TD]Belt Spec 450+/-150n Frequency range[/TD]
[TD]17.37hz[/TD]
[TD]21.27hz[/TD]
[TD]24.56hz[/TD]
[/TR]
[/TABLE]
[TR]
[TD]V-Twin Belt All Models (2013) and RS/ST (Year 2014)[/TD]
[TD]Min (900n)[/TD]
[TD]Spec (1050n)[/TD]
[TD]Max (1200n)[/TD]
[/TR]
[TR]
[TD]Belt Spec 1050+/-150n Frequency range[/TD]
[TD]30.09hz[/TD]
[TD]32.5hz[/TD]
[TD]34.74hz[/TD]
[/TR]
[/TABLE]
[TR]
[TD]ACE 1330 Belt Model RT (2014)[/TD]
[TD]Min (900n)[/TD]
[/TR]
[TR]
[TD]Belt Spec 1050+/- 150n Frequency range[/TD]
[TD]32.34hz[/TD]
[TD]34.93hz[/TD]
[TD]37.34hz[/TD]
[/TR]
[/TABLE]
The gates site is http://www.carbondrivesystems.com/products/accessoriesandtools (bottom right corner)
You can also go to Apple APPs and do a search on Gates Corporation
Yes most of the various parts of the APP are dealing with a bicycle it doesn't matter. We want the frequency of the tapped belt.[/QUOTE]
Your train of thought is absolutely correct. In fact one could simplify it by adjusting the belt to the Spec Frequency by using the above table for your year/model Spyder. Take the average of the three readings and your good to go.
The only problem I see with using the Laptop method is the operator has to have the knowledge on where to take the frequency reading on the recorded signal. The recorded signal will present itself as a decaying frequency so you would have to provide some kind of training to explain where to read the waveform to get the frequency. The APP and the 507C sonic meter are programed to read the signal and measure it the same all the time.
I have talked with SL (magdave and ahh-cool) and they have used the Android with the Continental APP and got the same readings of around 80 hz which is wrong but constant. SL (finless) explained the as poor quality chips being used in the Android devices.
Two different animals
The belt tensioner you are referring to I assume is the aftermarket one sold by various SL Venders. Correct?? To my knowledge there is no tensioner for the SPYDER that automaticly sets the factory belt tension. Factory belt tension must be set per procedure in the service manual using a Electronic Meter ( Gates 507C Sonic Meter). The procedure not only sets the belt tension but also ensures the belt is tracking true to the spin axis of the front and rear sprocket.
The aftermarket tensioner you are referring to is used by some to dampen belt vibration at high speeds. Basically what this belt tensioner is doing is applying pressure to one side of the belt in the middle of the span to stop it from vibrating.
The procedure not only sets the belt tension but also ensures the belt is tracking true to the spin axis of the front and rear sprocket..
If your saying that once you set the freq to the correct place that it will run true, I'm not sure if I agree with that. I believe that is two separate procedures
I believe you need it to run true and then set the tightness
Stefan
If the conversion is calculated, for the 2013 and newer models, then the belt tension should be set at 202-236 lbs.
For the older models, 67-101 lbs with a max of 134 lbs. (which seems too loose to me, but that's the conversion)
If the belt tension is set properly, why would you have vibration? Isn't vibration the product of the belt flapping?
Stefan
Agree
Any time I loosen the axle nut I always do the belt alignment and tension as one procedure. I do this by first getting the belt to track true with the tension at the low side of the spec. Once the belt is running true then I have matching 1/4 " ratchets with 6mm hex on the adjusting bolts. Using two ratchets makes it a whole lot easier to bring the belt up to the proper tension while maintaining the alignment of the belt.
The belt will set up some type of vibration ( harmonic) as a result of the span and the speed the belt is moving and any irregularities in the belt due to the manufacturing process. All belts do it even when tensioned correctly.
Doc, is there a disconnect in your avatar? The line above the pic says Orbital Blue, but the pic shows, what looks to me like, a Lava Bronze RT. Or am I just missing something?
I can't change that. That was my 2010 RTS. I now have a 2014 RTS.
F3 2015 Australian spec
Hi,
thanks for the thread,
would you mind finding the frequency for the Austraian spec f3
we run a different rear sprocket which gives a different mass of 8.4 g/m not 8.0
these are the specs for the 2015 f3 353 mm sprocket
belt tension 775 N. +/- 150n. 174 lbsf. Min 140 lbsf. Max. 208 lbsf
mass 8.4 g/m
width 28.0mm/R
span 980 mm
fyi USA version has 397 mm sprocket with 8.0 g/m all else is the same.
really appreciate saving me the time and effort to find the the frequency.
thanks David
