I believe that all of the pre-2014/15 RT's had the dual action Parking Brake/Frunk Opening switch on their dash panel below the handlebars, but in my experience and that of many others, apparently now including you
@NorwegianRT, the Frunk Opening side of the switch
repeatedly fails while the Parking Brake side still works. I've tried fixing that with a replacement OEM switch a number of times, but the OEM switches just don't last for long!!
I have also done a few different tests using a variety of a/mkt Carling switches to operate
JUST the frunk opening, leaving the Park Brake still functioning fine on the original switch; but regardless of the switch brand/type, that solenoid opening thing just doesn't work reliably/open the frunk
ALL the time - regardless of the switch type, it would sometimes take about 10 or more switch operations to get the frunk to open. The problem appears to be a lack of sufficient power getting thru the switch to the solenoid, and I believe that the power level in that circuit is controlled by the circuitry in the dash module, something I'm not prepared to play with!
So altho I've got a switch in the dash panel, I've basically given up on the '
Switch opening the frunk' option, relying instead on the '
Push in & Turn the Key' operation, and I do have a hidden 'Emergency Release'!
That said, I believe that one
MIGHT be lucky enough to get a switch to work the frunk opening reliably by running a completely separate power circuit direct from the battery thru a key activated relay and an alternative switch and wiring to the solenoid, effectively completely by-passing the OEM wiring, but I haven't tried that - it was just too much bother. Still, my latest 'alternative switch' installation
WILL open the frunk maybe 1 or 2 times out of every 10 or so attempts, but I rarely bother with even trying it these days.
