I have had that problem since day one. I just go into R and then it goes into N. I can get into N from 1 but it's a frig - I just go thru R.:shocked:
This is NOT normal, and I'd recommend that you should have your dealer look into this. When you have an SE5 equipped Spyder, you should shift it into N before shutting it off. In order to shift into N, the bike must be completely stopped and not moving. The ONLY reason a NORMAL SE5 Equipped Spyder should NOT Downshift into N from 1st gear, is if its still moving and you try pushing the thumb shifter, then it will ignore your input.
I have a small problem the :spyder2:will not shift into neutral from 1gear. It dose go into neutral when I start it. I have a 2011 RTS just turn 4100 miles. any Ideas on what it could be? is it something I can fix or do I need to take it to the dealer:dontknow:
Sounds normal to me. "will not shift into neutral from 1gear. It dose go into neutral when I start it." Sounds like the Rt was off when you were trying to shift into neutral but it shifted when you started it like it should. The SE5 will not shift when it is not running. It will auomatically shift to neutral from 1st when it is started.
Check the oil level. SEs are quite sensitive to having the correct oil level.
If none of these seem to be the problem, see your dealer (or learn to live with it). One of your clutches may be developing problems.
Sharbill;
The buzzer sounding, has nothing to do with the position of the transmission. The buzzer is indicating that the ebrake is not on.
I'm viewing this thread with interest. My new RT-S is going to be semiautomatic. My previous spyder was manual. ?......To shift or not to shift into neutral after stopping and wanting to shut down?
Chris
Chris
on my 2012 RT Ltd SE5 the buzzer indicates that it is still in gear.
