ARtraveler
R.I.P. Dwayne
Now I'm confused... :shocked:
Does that make me immoral; or amoral?? :dontknow:
If/when you figure it out, let me know. I am stuck here too. :roflblack:
I love manual so I may not be the best source..that being said..I have seen more problems with clutches on the auto and shifting issues as well. I prefer the control, pulling in the clutch and coasting the downhills, slipping the clutch when needed, being able to run at lower rpms without clutch slipage, parking in gear and operating park brake manually. I do understand those that like the SE models but it doesn't fit my ryding style...in the end it is your choice, maybe a longer test ryde...:roflblack::roflblack:
...................The SM-5, and SM-6 are very different transmissions and come with very different engines ..............so you are comparing apples and oranges ......just sayin ..........................and say what you want buuuuuuuuuuut I won my class at the last SPYDERFEST drags with the SE transmission ......just sayin .......Mike
Took mine in to get inspection and check up. Took the st se for a ride decided to play a little man that thing power shifts real sweet. Don't tell the dealer, won't name him:roflblack:.
The reason I mentioned the SE-5 vs. the SE-6 is the SE-6 with it's clutch operate quite differently from the 5's and IMHO will not have the issues they did........MikeMike,
I'm just saying that the SE controlled transmission can have more problems than the SM transmission. :congrats: on winning your class at the SpyderFest drags.......Thanks :thumbup::thumbup::thumbup::thumbup::thumbup:
Mike
And doesn't require 2 hands on the bars to do it.
I'm just thing to figure out why every thread in the GS/RS shop section get flooded by responses from the RT crowd. Most of which can not accept they sit in a different rider spectrum than an RS and RSS rider / buyer. Every dang thread. Sigh. I wish the mods would at least point this out if not fix it. It spoils the option for us non RT riders to discuss things, as we are not as concerned with farkles (and good lord what is a farkle), and more out to have an engaging ride.
end rant
The SE is a as annoying as any other automated clutch manual. Unpredictable, less reliable, and has caveats to keep it alive. The only discernible advantage is bad traffic laziness. Which is far harder on the clutch than the lower rpm engagement options on the SM. In gridlock I felt like I was a abusing the SE clutch.
